dragons tiger I initial prod 3 in 1 sPzAbt 502
I just recieved this kit the instructions are a bit confusing.mainly step one installing the suspension arms there is an inset window showing you to trim off the locating nubs but only on one side this is the part that confuses me the inset picture shows the hull turned upside down with the right side facing you, but the main picture show the hull right side up and taking the nubs off the left side. which is correct? and why is this neccessary? please help
I guess you are looking at Dragons # 6600.
You can probably make that suspension work but I would give it a miss.
If you are not interested in showing of the interior make your life easy;
Forget about the torsion bars, leave the locating nubs for the swing arms and glue them in place.
As always
Boarder
thanks I will do that
