Hi guys, here,s what i have been working on this week beside finishing up the paint work on the ones i had on the bench this is a beauty of a build it is just easy and fun and i enjoyed it imensly much more so that i thought i would.
Dragons Bergepanzer Tiger 1 (P)
I was having a hard time deciding what kit to build next so my attention was drawn to this one. This vehicle has always been one that i wanted on the shelf but it constantly got pushed down the pile because of other vehicles i was more excited about building but not this time. This is the Dragon Bergepanzer Tiger (P) and i have to admit i just like this chassis and all the varients that were built from it.
So on with the build,
There are four options in the kit two being early versions and two late and i will be going with the “1st company, sPzJgAbt 653, early” with the three colour camo to avoid having to do zim as i have a few builds coming up which will need zimming so im saving myself.
Step 1 as always involves cleaning and putting together the wheels and bogies which clean and fit together very nicely and look great when done.
Step 2 covers putting together the lower hull and removing some details which i assume are there from the elephant/ferdinand kits but are not needed for this one but its no big deal just a quick swipe with the knife and a little sanding. Another thing to take of is you need to drill out a couple of locating holes for later on in the build so keep a close eye out for these.
Steps 3 through 6 involve attaching the bogies and wheels and adding the tracks which is very simple and goes well but i was a little worried about the tracks, when i first removed them from the card they had very stubborn fold marks and i didnt think they would be usable so i took a bowl of water and began heating it in the microwave, at several points i dipped the tracks in it but to no avail right up until i got the water so hot small bubbles began appearing on the bottom of the bowl but it wasnt quite boiling, i dipped them in and out came the folds so i quickly placed them on the model so they could form nicely around the wheels and i now i believe they will work just fine.
Step 7 and 8 consists of the front plate, upper deck and fenders which again go together very well the only note to make is i had to spread the tub a little to get the deck in but once its in it holds together perfectly.
step 9, consists mainly of the front hull and upper deck details and hatches.
Step 10, continues on with the upper deck details.
step 11, this is the front side of the turret (not sure what to call it but turret gets the point across)
step 12, covers the rear of the turret.
And the turret mounted.
step 12 continued, finishing up the detail on and around the rear lower hull.
Step 13,began with the jack assembly which is comprised of 5 parts plus a PE clasp, here you should ignore the placement marker on the deck for the PE clasp because it is to far to the rear and the jack wont fit i had to remove it and move it forward.
Step 13 continued, the deck vent cover and handles
And the final steps are 14, 15 and 16 and this is the boom and what a nice piece of work it, is it took me a few minutes goin over the instructions but if you go slowly and keep to the steps there are no problems at all the only thing is the chains are too long and do need trimming down once you know exactly how where you want everything to be.
The instructions for step 14.
This goes together great without problem the booms themself are also very clean and easy to assemble, once the chains and pullys were done it was a simple case of setting the booms in their mounts, attaching the pully’s and chains then gluing the whole thing down and here is the result.
I also added a tow cable the kit supply’s wire and ends for two but one would have gotten in the way so i left it off.
up next is Painting Dragons Bergepanzer Tiger 1 (P) stay tuned,
Thanks for looking and feel free to ask any questions or comments.
Ron.
