If anyone has built this kit or knows the real tank that would be cool.
Early on in the build you have to cement 2 thin strips onto the side of the top/deck.I think these then hold the side skirts.
Should the join around the deck be visible or would this be one piece in real life.I have very little in way of photos to go by.And what i have seen on line does not show the area in question.
There are recessed lines going up the strip which i understand shoud be seen.
Sorry man, I’m trying to visualise what you’re talking about, but I’m having a hard time. I’ve got a T-72 from DML in the stash, I’ll take a look tonight if its a similar situation. From what I understand, all of those series were based on the same mouldings from DML. I have a bunch of pics of T-72s, so maybe one would apply here. PM me if you can.
The T-80 and T-72 were two separate and distinct tanks. The T-72 was the successor to the T-55 line and the T-80 was the successor to the T-64 line. Both kits have nothing in common.
It’s been a while since I first built the T-80, close to 18 years. I don’t recall the construction step you have a question about. I do remember that the kit tracks are too wide. If you install the tracks as directed, the upper hull will not fit on the lower hull. The solution is to either eliminate the upper run of tracks (they are hidden by the side skirts) or to slice off the end of the tracks until they will it under the upper hull with the side skirts attached.
I commented because I had one of the T-80 kits that was reboxed by Kirin, and it contained the exact same lower hull moulding as the T-72 kits from DML, so I assumed the rest were fairly the same.
Kirin did only two “Soviet” armor kits, both were variants of the T-72. One was the Yugoslavian variant of the T-72 called the M-84 that came with both Free Kuwait markings from Desert Storm and Yugoslavian markings, and the other was the T-72M1 Lion of Babylon of the Iraqi Republican Guard.
I am not aware of Kirin doing a rebox of the Dragon T-80 series. They did do a resin conversion to make the T-72 into the T-90 though (conversion #28521).
