hi mates, here’s one i made in between armour builds, it’s a bit converted dragon schutz (kampfgruppe hansen 1944) in 1/16 scale. there’s been a bit of work on it as all the molded detail has been removed and replaced with alu and copper foil ( new brackets on and staps , ammo belts and arms work [;)]) so please give us some hard critics so i’ll now were there’s room for change or improvement. hope you like them [:D]
Luc.
original:
Wow looks super great !!! I like how you made it fit into the scene really good.
It might be the pictures to me but the gun does not look enough like metal not enough shine mabye ?? Also i think adding black wash over all the edges would help bring out some parts. Also you might consider what he would look like if he was out in the cold awhile like your ears would be red and face kind of pale because of the cold. Thats what i think about it and you did a great job on it !!!
Excellent work. The modifications really add to the detail & realism of the figure. Thanks for sharing.
Regards, Rick
[tup][tup] Excellent work maffen,
This is one kit I looked at and gave a miss due to the ammo belt supplied in the kit as I could not think of way around using it . You have given me food for thought by your conversion work. Thanks for sharing.
