Those elegant vessels of yore, whether of the days of Tall ships or the days of Steam and Diesel. Why do those monstrous looking things called Passenger Ships today run like scalded cats when the weather gets bad?Well, there’s a little tale to be told here. The best example of how NOT to in my opinion to build a ship, is like the method used in vessels today-Like the Costa Concordia and others of her ilk!
Back in the Day the Ships that carried Passengers were maybe seven or eight decks enclosed in the visible hull, then maybe four decks stacked like wedding cakes above .Ships today go straight up from a four or five deck visible hull, to eight, ten and twelve decks with Verandas on them. Water tight? Nah!
Even the Area below the waterline is less than back in the day. I have to wonder why the old formula got thrown out the PortHole! Up till the Princesses and others of today came along. There was a rule that governed width and heighth . It was called Center of Gravity. Why does a passenger car, or van, for instance lean in the curve. It’s got a higher center of Gravity than a formula one car! Ships are the same.
Have you ever seen a photo of a Carrier in an All emergency turn to port or starboard? The slant of the deck( Flight Deck, that is) would astound you! Pumpers and Ballasters run from one control panel to another to shift Water, Jet Fuel and Ship Fuel around to keep her center of Gravity just so . This also applies to how the Planes and Gear are stored on the flight Deck and Yes, in the Hangar deck too.
So when you don’t have Deep Draft, But you have heighth ( which means a Higher center of Gravity) and lots of sliding doors that cannot keep out the sea. What do you do? If you are out, you run like Hades to the nearest safe port and ride out the weather!. Jeez, Tankers and Container ships can’t do this!
How many times have you seen container ships leaning over with part of their load spilling over the side. Happens more than you think. They have cables and stack stabilizers to keep everything in place BUT, mother Nature could care less. And her 30 and 40 and 50 foot waves pack one hades of a wallop. Don’t ever forget that! How many times at the beach has an incoming wave caught you off guard and knocked you off your feet. Samo,Samo, way out at sea.
The Wasa didn’t even make it out of Stockholm Harbor. She capsized in a light breeze because the CG was too high. It wasn’t the guns, which accounted for maybe 5% of the the ship’s weight. The King kept adding decks during construction without any real modifications to the hull.
Big waves do pack a wallop. I remember reading that one of our task forces got caught in a typhoon towards the end of the war. One of the carriers buried her nose in a big wave. When it sluffed off, the first 60 feet of her flight deck was bent back to the vertical. The Captain was supposed to say it would make a good sail with the wind in the right quarter.
Our CG Cutter, Storis, would frequently roll 45 deg in the Bearing Sea. We hit a rogue wave head on while sailing our usual patrol area. I was on the mess deck playing solitare when BOOM, the cards all slid forward as well as me. After picking myself up off the mess table I looked through the porthole and saw green water. A split second later the GQ alarm, dong, dong, dong went off. My station was in the radio room behind the bridge and as I was entering it, I heard the bridge crew discussing the wave. We didn’t lose anyone overboard thank God but it was quite a spooky situation. I’ll never go back to the Bearing by choice.
That my friend would be the U.S.S.Hornet. there’s a picture of that one in the U.S.S. Hornet Museum in Alameda.Whatta scary photo! Oh, I believe that was one of the bigger ships in"Taffy 3", I was wrong I guess, thanks guys. But, does anyone know why so many ships in Taffy Three were lost?
The Shell Orion -8-million Barrel,1,494’ tanker caught a rouge wave up there. We were carrying the 8 Million at that time. So we rode low and heavy. Oh, the forward bulwarks at the bow were ripped off like cardboard! It sent us to an off loading port and then to the yards. Can you believe that four of the five decks in the house were dented inward about three foot and busted every window in the Passenger quarters.
The yard in Liverpool had a new deckhouse ready in a week. In that case, Modular is good. The engineers figure the wave was about 80plus ft and probably packed about 2 million pounds (Tons?) of energy in it’s hit! The fact is Salt water is actually heavier than Fresh and in that kind of situation no ones knows how it’s going to work out. All you can do is pray! We were going slower because of the weather too, about ten Knots. We couldn’t go slower in that weather because loaded, we wallowed badly in that kind of sea! The hit stopped us dead in the water for about four minutes before the screws got us up to speed again.
What Class of Cutter was she? I am only familiar with the Treasury class(Hamilton and Taney) and photos of modern " High Endurance" types although I really don’t know what they are called.
Oh and a P.S., We discovered when we went to the offload facility we had no Anchors either! And a very dented, Below waterline Bulb. No leaks though.
They were operating on the fringes, no one could really believe what popped over the horizon. By the time help could get there, it was pretty much over. The CVE’s were built on merchant hulls, virtually no armor and a flank speed with everyone rowing of 18 knots or so. Biggest gun on our side was 5", against everything up to 18", and up to twice the speed.
Only thing that saved the rest was that Kurita thought they were fast carriers, and broke it off just as air strikes were coming in from other Taffy’s. Since he thought the were the fast carriers, he would be worried about the fast BB’s as well.
The escorts sacrificed themselves to try and do as much damage as possible with torpedo runs, and cover the escape of the carriers. Only ended up losing two carriers, but the escorts paid the price in blood.
Generally blamed on Halsey’s decision to send the BB’s after the decoy carriers, after Kurita turned back the first time. Then Kurita doubled back and the stage was set.
Halsey wanted to end the threat of Japanese carriers once and for all, which is why the Japanese plan put them out north as a decoy force, so the surface ships could slip in and wreak havoc with the landing forces. Suspect that Kurita didn’t expect the CVE’S covering, or their existence, so thought he was up against the fast carrier force.
love the sea stories that these topics bring out. i was chief mate on a large military sealift RORO back in 99 and we had to do a yard period in the old beth steel graving dock in baltimore. trick was i had to get this thing light enough to basically squeak over the sill which required pumping off every little bit of fluid i could including lube oil and fresh water (which the engineers hate to do). so my calculations had us showing the smallest sliver of positive stability , which in theory should be enough to keep her upright , but was still a hair raiser. my guess was the Vasa had neutral stability , where the center of gravity was same as center of bouyancy , then all it took was the wind…
USCGC STORIS (WAGL/WAG/WAGB/WMEC 38) was a one of a kind cutter commissioned on 30 Sep 1942. She was basically an enlarged 180’ buoy tender. STORIS was 230’ LOA x 43’ beam; the 180’s were 180’ LOA x 37’ beam.
I was stationed on USCGC CONFIDENCE (WMEC 619) in Kodiak, AK. CONFIDENCE is 210’ LOA x 34’ beam. During one patrol, Dec 1982 in the western Aleutian Islands, we caught a freak wave off the port quarter and rolled 65 degrees to starboard. I was on watch in the engine room at the time as Engineering Officer of the Watch. We took about 100 gallons of water throught the starboard air intake, which is over the starboard switchboard - we went dark ship real fast. We recovered from the roll, restored eleictral power and seized a pari of fishing boats for fishing an a no fishing zone.
210’s probably didn’t ride any better than the Stoypig. As an ET2 (only had 2 ETs), My responsibility were all radios, radars and Crypto. I would rather have been on a 210 or 378.
There was a site called oops list that showed all sorts of accidents with aircraft, vehicles and ships. One was a container ship that tipped over while still at the dock. There were a couple photos that showed a stack of containers that tipped and hit the ones on the other side of the ship. That may have been the same incident.
The 210’s did pitch and roll a bit if the weather got rough. CONFIDENCE would sometimes foll 10 degrees into the pier at Kodiak when the williwaws came off Old Woman. The 210’s drew 10’ maz draft. I was the DC1 on CONFIDNCE July 81 - Aug 83, when I transferred to Base Milwaukee. Then I was assigned to USCGC VIRGORUS (WMEC 627) in New London CT, where I made DCC then CWO.
Tanker Builder,
Most of kit makers see little interest in producing USCG cutter & boat models. The STORIS was a one of a kind ship. During WWII she was painted in the Thayer Blue camo and carried a Grumman JF-2 Duck on the stern with an aircraft handling crane. The twelve 210’ WMEC’s were originally built without vertical stacks; the engines exhausted out the stern. During their Midlife Maintenance Activity, all of the engine and boiler exhausts werre routed through a vertical stack. The emergebcy generator located in aft steering retained it’s exhaust out the stern.
Are you refering to the 110’ WYTM’s built by Ira S, Bushey & Sons in Broojklyn, NY? Check the Coast Guard Tug Association, there are pictures listed under the CG Tug Fleet tab.
And bigger windows sell better (or are priced higher).
The days of a cabin with a single 24" porthole are long gone.
So, they stack cabins built of flime-flam and light scantlings 10 or 12 ‘floors’ tall, and in a “U” shaped hull girder. The internal “atrium” spaces sells pretty well, too, particularly for being climate controlled.
Now, how they manage to have enough tankage for stowing enough water to allow all the passengers 4 or 5 hollywood showers a day still boggles my understanding of geometry. Most of thise floaty hotels have additional condensers specifically to generate fresh water 24/7.
Short travel distances no doubt assist in being able to operate these beasts without needing more stowage.
Mind, the “river” cruis ships double down on this, too.
As to storms, the Ocean is vast and deep, and cares not a whit for the egos of mere men and their constructions, mote-like upon its face. The mass of the sea is inexorable.
