Do You Want Classic? In 1/250?
Okay;
Now those of you who are interested mainly in Warships don,t have to be bored by reading this. Those of you who like unique Civilian vessels, Listen Up!. How about a 1/250 model of one of the most Iconic ships to meet her end outside New York Harbor?
Yes, I am referring to the Andrea Doria! Now, can you believe this is made of Cardstock? Not Paper, per se. Cardstock. Why ? I would imagine it has something to do with the vessel’s size . she’s 32 3/4" LOA. Not only that she can also be built as her better fated sister, the Cristoforo Colombo !
Now I know, you’re saying this should be in Papermodels. Why? at this scale these can be mere patterns for the Scratch-builders and Kit bashers among us. In plastic! Yup. Lotsa packages of Evergreen better be in your building materials stash. Especially in .020, .030, .040 and maybe two pks. of Assorted tubing.
I do believe it would be prudent to check this kit out. Well, Why? How about this, it’s a double kit that costs less than one Detail up kit for Tamiya’s Enterprise A/C/Carrier or Missouri 1945 fit Ship. Yup ,you guessed it, the other ship is indeed the Stockholm! At 33 1/4" inches. Now here’s the kicker, I also received the Lasercut detail up kit for the paper Model of the Mellum that I have mentioned in earlier posts. The Mellum is a smaller scale, But this detail up kit is awesome.
Folks, this is unbelieveable! How about full color detail up equipment thinner than Brass, but, every bit a beautiful as any you could buy at any price! For the whole Mellum which has at least a page and a half( translate to a fret and a half of brass) of heavy colored card colored all sides and as delicate as a clock spring for rails and ladders! Cost 22.79 Euros ,V.A.T. included. The ships were 40.25 eu. and the detail up set for them was 25.00 eu
The total for the whole package was 87.93 eu. Could you buy that many hours of plastic ship fun for that price anywhere? That’s the other reason I did NOT put this in Paper-Models. I figured if you weren’t interested in paper or heavy card you wouldn’t read the post.
I just had to do it this way. Can you believe Watertight doors and Ladders that build the same way as brass but in full color and scale? Really. Now I have noticed that they are, For you W.W.1 enthusiasts out there, starting to pop up with many more kits of Monitors and Dreadnaughts in the heavier card at 1/200 and 1/250. Yes, most are waterline, but, how many of you care about the ship’s bottom anyway?
These are proving to me that this is a modeling Media that is definitely coming of age and you can use etched brass with them and you don’t need fancy painting gear and all that stuff, If you Don’t want it! Or Can’t afford it! A good small set of Artists felt tip pens, Sharp scissors, A pair of Curved blade( small) scissors, A Rotary Cutter( Got that idea from my landlady) and the only glue on your table need only be Aleen’s Copper Bottle Tacky Glue! And a good pair of Philatelests tweezers( Stamp-Collectors) and a sharp pointed pair, for the teensy parts.
I must ask, Check them out and if you want, ask Don Stauffer about this media in ships! The sky is the limit in whatever genre you want. Plus, they probably make a lot of ships and ship types, you’ve probably never heard of!
Here’s another twist - are you at all familiar with the Silhouette or Cricut cutting machines? I bought a Silhouette Cameo4 in January. So far, I have used it to make paint masks and to cut out parts from styrene for my RC scratchbuilds.
I am bringing this up here because it also has real potential for use with paper models.
The pixscan tool is pretty powerful. I did a test using a simple paper model. I took a section of a commercially printed 15mm (1/100) war game structure (wrecked house) cardstock model, put it on the sticky scanning mat, and took a photo with my phone. I then imported the photo into the Silhouette Studio software, and used the “trace edge” feature to find the outline. I then loaded the mat with the paper model still in place into the cutter, and it precisely cut the item out!
This was a learning exercise- it would have been quicker to just cut this simple item out with an X-Acto knife. But it shows some interesting possibilities…
The powerful feature is that you aren’t limited to just cutting out the exact item shape you scanned. Once it is imported, you can take the outline of the item you generated and manipulate it, paste it into another file, and then cut it out on a different material. A couple of examples come to mind:
  1. Scan parts of a decal sheet, maybe scale it up if needed, and then cut masks for painting the insignia and letters. Scan a generic letters or national insignia sheet, and you now have a library to cut masks in whatever scale you need. I have a clubmate who has done something similar-- he has the previous generation machine. He was building a specific 1/48 Spitfire, using an aftermarkmet decal sheet. His problem was that the sheet had an error- the fuselage squadron letters were the wrong color. So he made a mask and painted them in the correct color instead of using the decals.
  2. Scan a paper model, and then cut parts of it on a different medium, say thin styrene. This has me very intrigued- I have a need for a 1/96 scale Curtiss SOC-3 floatplane to go on the stern of an RC model. My only options in 1/96 are a (heavy) resin model or a “print at home” paper model. The paper model is a lot lighter, but won’t be as sturdy or moisture-resistant.
    Cutting at least some of the model out of .020 styrene instead of cardstock has potential…!
A ship in 1/96 capable of carrying a Seagull on it’s stern?
That must be something!
R.C.Boater;
I built two patrol aircraft for the 1/96 scale North Carolina out of paper. I then and before assembly coated those parts with craft clear semi-Gloss. Assembled them and sprayed them again. They lasted five years before they got to banged up to use anymore.Just a note to solve your problem.
GM,
Yes, it is the USCG Secretary class Cutter. When the class entered service in 1937-8, they could carry a Grumman J2F or a Curtis SOC floatplane on the aft deck. I have a Scale Shipyard 1/96 scale hull, about 40 inches long. Before I can build a model, I need to pick which ship and from when. One of my favorite options was inspired by this photo of Duane on the Greenland Patrol in 1940…
Oho!
What I think is one of the most beautiful U.S.C.G. cutters ever designed !!!
One of our members has provided a hand written diary from his father of the month or so the pages contain of service in Iceland aboard the AO Rapidan in 1942.
Right way in the first pages it’s noted that she was a replenishment ship for USCGC Bibb, among others.
