I am having issues changing colors, my Iwata neo CN airbrush works great when it’s perfectly clean but when I clean it out (on the fly) and try to spray a different color it works less well, still okay but not perfect, if I change to a third color, it a complete disaster, I use water and solvents from the manufacture of the paints to clean the airbrush and I am using Tamiya and mission model paints exclusively and I follow the directions to the letter
As a “newbie” I’m reluctant to blame the tool, so I was wondering if this is normal. Do you need to deep clean your brush every two colors (completely take it apart and scrub everything)?
I have a suction feed airbrush and I do clean it after every use, but not a complete disassembly. I run lots of thinner through it, backflush, and keep thinner in it after cleaning. When I change colors I do at least a partial disassembly. Cup types- gravity flow, are a bit easier to clean but I think you should do some cleaning after each use, even if you intend to use same color next, especially with fast drying acrylics or lacquer.
I think the trick is to keep the brush from drying out. When I finish using one colour I pour/wipe out any remaining paint from the cup and run some thinner through the brush, then leave a little more thinner sitting in the brush for a few minutes to dissolve any partly-dried paint. I also give the tip a wipe with a cotton bud dipped in thinner. Then pour out the thinner (and any dissolved or dislodged paint) & then spray a few drops of fresh thinner, before adding the new colour to the brush. After about 10-15 minutes’ use, I do this anyway, even if I’m not changing colours.
I use the IWATA TRN1 Trigger style airbrush and i can use three or even four colors at a single sitting. Here is my routine for cleaning between color changes
Dump excess paint from the cup
Use either IPA or manufactuers thinner in the cup and use a cotton bud to clean out the cup and the port under the cup while i am running the thinner through the gun
Repeat step three at least 2 more times.
When the IPA or thinner comes out clear you can then change to a different color
I use primarily Vallejo or Vallejo-like products through a Badger 105 Patriot.
When finished with a color I dump any excess and wipe the cup with some paper towel. I fill the cup with some windex (Tip: I have a squeeze bottle with a spout to dispense the Windex - think of a kitchen ketchup bottle.). Swirl the windex with a old paint brush and spray out. If im going straight to a second color I will put a bit of clean thinner in the cup and spray that out. Then add the next color thinned to sprayable consistency.
I dump colour out of paint cup & swill with water, then dump that & fill cup with IPA, or appropriate thinners untill it runs clean.
I don’t put water through the brush as despite Tamiya acrylic being nominally capable of being thinned with water, I find it beads up, & seperates with too much water rather than diliting equally.
Also water drops in the airbrush will affect the next colour.
I don’t use Mission Models Paint, but again compatability between it, water & tamiya remnants is a possible culprit.
