Do I strip the primer off?
Hi guys,
As a rule, I don’t really prime my models before painting. But this time 'm working on a Collect-Air resin kit. That being the case, I applied a light grey primer. In doing so, I could see all the pinholes in the resin which I missed. My question is: Do I fix the pin holes and disregard the primer or should I note the locations of the areas in need of fixing, strip the primer, fix the flaws, then reprime? What would you do?
Thank you,
Eric
On resin ship hulls, I will fix the gross spots first, then prime. Any small spots which the primer reveals are then fixed and they are then spot-primed. A light sanding - or even a buff with an old t-shirt - will level & blend the two primers.
It depends on the adhesion of the primer—hopefully anything you use for a primer will have great adhesion. In that case, just fix the defect, sand, and spot prime. If you are using automotive body compounds like Acryl Blue, they bond well to just about anything that has a clean surface. Same with CA, but it may lift acrylic primers. In that case, I lightly sand the spot, repair, and spot prime.
Thanks to all for responding. I’m using the Testor’s grey primer over resin. After it let it set for a while, that’s when I noticed several scratches and pin holes that I missed. I was thinking of using some Mr. Surfacer 500 on the air bubbles but I wasn’t sure if it was okay for me to use it right over the primer or if I should sand off the primer first or if I sure use thinner to strip off the primer in the trouble area and then use the Mr. Surfacer.
I’m not using any automotive body compounds, just the Testor’s primer. Then I was going to use Testor’s Model Master enamels over that for the top coats.
Thanks,
Eric
