http://www.dragonmodelsusa.com/dmlusa/welcome.asp
On the heels of the Trumpeter release!
I just saw the new Panther D with zimmerit in my LHS today–$59.00! YIKES!
Too expensive for my tastes at this stage…
Both Trump and DML are increasing prices in the +15% range
HOLY [censored][censored][censored][censored]!!!
ARE YOU SERIOUS?!?!
WOW! [soapbox] I imagine that’s’s going to send even more guys over to ebay for their purchases.
Time to start building the stash I guess! Luckily I have enough to last for about 10 more yrears if I start now! [(-D]
Then again, cars are still “only” $14.00-15.00 now…[:-^]
I wondered when the manufacturers would begin add to the list of available products. You have to admit, if your looking for a plastic kit, you’re options are kinda limited to building the big 18t or the 7t “specialty” variants.
Wasn’t the 5t and 7t used for hauling most of the towed weapons?
Is this the same as the Tamiya, I thought the Tam wrote 18 tons, but from what I can see they look the same?
makes 1/48 scale Tamiya kits look good[swg]
Depends on the weapon and its weight class for towing. The 8t were the prime-movers for the 10.5 cm and 15 cm artillery as well as the 8.8 cm while the lighter towing half-tracks could handle the 7.5 cm PaKs for example. Since both Trumpeter and DML released heavy artillery kits earlier on, it would make sense that they are also both now releasing primer movers to go with them…especially since the Trumpeter kit was designed to be built in travelling mode only. [;)]
That would be a fun build and something I’ve never done. Maybe I’ll have to pick up the artillery piece and it’s tractor someday.
I wish someone would release injected styrene kits for the SdKfz 6 (5t) and SdKfz 8 (12t) halftrack schleppers. All of the others are available, so why are the manufacturers allergic to those two? They were used in significant numbers…
Mick
