Discolored decals
So I have these old Super-Scale F-4N decals in Low-Vis. There is a bit of yellowing around some of the larger decals. Should this preclude me from giving the sheet a shot, or can one proceed with caution here?
Thanks
Ray
if you want to get your decals white again i suggest tapping them to a window that is gonna be facing the sunlight for most of the day
the sun will heal the yellowness and give you white decals again!
Interesting . . . this does not fade the overall decal pigment?
yeah but shouldn’t you use a window that doesn’t have UV protection though ?
You may want to brush on some Micro-Scale Liquid decal film to make sure that the decals will be all-right when they hit the water.Sometimes older,yellowed decals can shatter when placed in water,the Liquid decal prevents this and insures a sucessful application.
