DIRTY PICTURES
Okay, hopefully that got the webmaster’s [hi, Aaron] attention. This post has nothing to do with dirty pictures. Except this:
There is a problem I’ve noticed: The following is an unnumbered (bullet item) list with large ROUND icons:
  • First item
  • Second item
  • Third item
The following is a SUPPOSEDLY numbered list (Arabic numbers in increasing order):
  1. As viewed in Edit, this is “1.”
  2. This is “2.”
  3. And this is “3.”
The problem is what I see as I edit the post is NOT what one sees in the final thread. Both of these lists display using small square icons.
Anybody else notice this? Can we get it fixed?
Okay, I got Aaron’s attention. The bug has been fixed.
This is a test list with bullets:
  • item one
  • item two
  • item three
This is a test list with numbers:
  1. item one
  2. item two
  3. item three
Heh, never noticed before, but you’re right, they are broken!
At first I thought it was due to the font you use, but I’ve tried numerous fonts and they all give the same results.
So, Aaron, up to the task of fixing this issue? [:D]
You had me getting my hopes up. Only dirt, not dirty.
