Hey guys, I just did a couple of simple plaque base dios for my MLRS and AAVP7A1. I masked the top, painted the edges black and when the paint was dry, top coated the newly unmasked surface with spray adhesive, then shook on some hobby sand. I built this up several times until the wood grain was no longer visible. However, it still doesn’t have the realistic effect I was looking for. Anybody got any suggestions for adding relatively inexpensive realism to the “sand”? Thanks, Todd
post a picture. a little confused
Here’s some pics of what I’ve got, hope they help. For some reason, I can’t get the one shot to rotate right, sorry. Thanks.
Ok…
I see what you mean by unrealistic, it looks too flat and uniform. You would need to add some more depth to it so that the vehicles look like they are travelling through the sand rather than floating on top of it. Some track marks, a little more depth, ripples (if representing wind-blown sand) and some tonal variation will help. Also, unless this is set in the middle of a sandy desert, perhaps a little variation in the grit size (rocks, pebbles etc).
Next time, put a thin layer of Celluclay, epoxy putty or plaster of Paris on the plaque first. While the base is still moist, push your vehicle into it just a bit. Then add additional ground cover after painting. For my ground, I use Celuclay mixed with model railroad ballast for texture, earth toned acrylic craft paint for color, Elmers type glue for adhession and a bit of water.
The problem you’re seing is a dead flat surface. That only happens on a golf green and a new mall parking lot. It just ain’t natural!
Phil_h - I greatly appreciate the help. I understand exactly what you’re talking about doing, but as far as the tonal variation goes, how do I accomplish this? Is it as simple as adding some different color sand to the mix, or do you mean a painting technique after the application? Also would this still be appropriate for a beach landing scene (for my AAVP7A1 which is amphibious). Im not experienced enough to attempt an acrylic water construction yet, but I thought I could at least simulate the sand. Thanks again!
ajlafleche - Thanks for the super tips. Im going to the store tomorrow to get some of the celluclay and railroad ballast. Thank you too!
Tonal variations will depend on what type of desert conditions you are trying to depict.
Actually in the middle of a wind-blown sandy desert, the tones would be fairly flat, with little variation. You would see subtle variations in tone where the surface is disturbed, as underlying layers may be a different tone. Wheel/track ruts, you could mix a small amount of pigments or ground pastels to the sand to represent this.
Where the surface is rocky or there are features like roads or other structures nearby, anything goes.
Try mixing a different color ground material in, or something with a slightly larger grain, in like, a 30-70% ratio…
Here is what I did with my M270. The sand is built up in layers. Once there is enough, track marks can be put in. Just keep layering to make it look wind swept and leave room for track marks. The M270 should sit in the sand and then put some sand on the tracks.
Getting the perfect color sand for Iraq will be difficult. I went to a craft store and used a craft sand which is uniform and small grain. If the grain is too large it will look strange. The color is a little greener than what it should be.
Remember this is fun. Always like to share ideas but perfection should not get in the way of enjoyment and your accomplshment.
Good Luck.
Thanks, Guys, to all of you! Your help is always appreciated.
