Diorama Hanomag Sdkfz 251/1 1:35
A little time ago I decided to start a new diorama. So I decided to use as a main subject Tamiya Hanomag Sdkfz 251/1.
Then I switched to the design of the location, and I decided to set the Hanomag during the battle of Stalingrad. Inside the diorama I will put the Hanomag that advances in the steppe accompanied by some soldiers, further there will be gunners behind some sandbags which cover the advance of their comrades.
Here are the protagonists.
Tamiya German Hanomag Sdkfz 251/1
Tamiya German Machine gun troops infantry
Tamiya Sand Bags
Army Painter Steppe Grass
ExtraDetail German Wurzeltod boxes
Well, soon I will post photos of the work. Sorry for my bad english, I hope I made ​​it clear [:)]
Bye!
Here is the little work I’ve done. Keep in mind that the pieces in the pictures have not been cleaned at all, I still have to shave them for good.
The control panel partially assembled
Installation of the track’s bearing
Assembly of the front axle
Finally, the installation of benches and the control panel
The work is quite long and tiring because the plastic is very old (the kit has almost 40 years), and tends to break easily.
Well, all for now. If you have criticism or advice expose as well. See you soon! :slight_smile:
