I had a quick question guys. What’s the best way to paint realistic Digital ACU camo for 1/35 figures. The task seems extremely daunting and time consuming. Unless they have some decals that can be paid down and formed using micro sol or solvaset. I appreciate any help and tips!
This came up about a year or so ago and all I can do is repeat myself. The decals are almost impossible to fit to a figure with the curves and folds of the uniform. Personally I think I’d take a small brush and do a string of dots along the edges by poking the brush at the figure to get the pixalated effect and then fill in the insides of the camo pattern. That’s just my two bits though, maybe someone else has bettr advice?
The square head of a toothpick can also work.
Decals are likely useless, you’d need so much solvent that they’d likely dissolve.
“Scale Effect” is your friend.
At 3" away, you are a scale 8 feet away. So, you really only need to generalize the color range, and then use dots to suggest the teture.
Use google images to get some examples of how that should look.
