Differences between early and mid Jagdpanther
I have several photos of Jagdpanthers from 1st company SpA 654 during August 44, mid production with zimmerit, all gear stowed on the sides, no tactical numbers, schurzen fitted and base coat of sand yellow , they had a camoflage pattern applied shortly after the photos where taken.
I want to convert Dragon’s early Jagdpanther to one of these mid production vehicles so other than fitting a two piece barrel and deleting a drivers vision block what else do I have to do?
have u drg kit 9012 if so ill have a look for u…stoo
so far the ribbing around te barrel and mantleton the late has four bolt holes at the bottom
plus the late has four exhursts to thr early two
the last thing i can see is the early has two small engine grilles and two larger ones…which are closer to the rear of tank…the late has all small ones regards stoo[2c]
Try here http://www.militaria.net.pl/strony/083.html
whoops, my screw up, I mean difference between early and mid versions, edited now.
no my screw up … go to the website piterpanzer said… i had two kits here tamiya late and dragon early my mistake[#oops]
