After years of whining and complaining about my dinky little canned air cartridges that I use for my Airbrush, I finally took the plunge and bought a
Scorpion COmpressor.
Without too much fuss I have been able to do large scale painting, but when it comes down to camoflage or the like I get spattery overspray all over the border instead of a nice fuzzy line.
From reading the forums I understand this is too much air pressure, but…alas…I have no clue how to adjust this.
I think the Scorpion is set to 40psi per the manual.
Nah, just go to Wal-Mart and get yourself a regulator with a water trap. It shouldn’t cost more than about 20 bucks and will do you right. Set your pressure about 15 psi to paint cammo, play with your thinning mixture and pressure to get the paint where you want it.
You may want to use some paper masks to reduce overspray-that stuff goes everywhere.
And of course, practice, practice and practice. I’ve still practicing after 30 years.
40 psi is about 5 times too much pressure. I painted this F-105:
at about 8 psi. Low pressure, thin paint, close to the surface, and lots and lots of practice fixing mistakes that I make.
I have ascorpion compressor with the auto shutoff… the shutoff is on the water trap that came with the compressor… I just put my regulator/water trap onto the existing assembly and the auto shutoff was not affected… just be sure to install the regulator past the auto shutoff valve and it won’t be a problem…
and by the way I think the scorpion air compressor is good choice… been using mine about 2-3 years now…
