Desperately in need of help!!!
I got the Revell Pro Modeler SB2C-4 kit and when I opened it; there was no clear parts!!! Does anyone know where I may find a new canopy???
Have you tried contacting Revell directly to see if they might have one for on hand? I know it may be a long shot,but maybe worth it. You could also check Squadron.com. They carry a whole slew of vacuformed canopies and I would think they should hvae one that would work for you.
Brian
In the instruction sheet there should be information on how to contact the manufacturer. You can visit their website and request replacement parts. I’m not sure but was this kit recently rereleased? If so your chances are better at getting the parts, if not they may not have them. Here is a link to their website.
http://www.revell.com/support/index.html
Lest we forget. Accurate Minatures is also using the Monogram plastic in there SB2C. You might try them as well. Check Squadron to see if they have a Vac canopy set for the kit as well. Either option will give you better clear parts than those that came with the Monogram kit.
