Decanting tamiya spray cans
Hi there
I decanted some AS 26 paint this morning and let it settle so all the gas could escape. I went to use it tonight and it gummed up my airbrush. can any one help? Thanks
Had it already started to dry and wouldn’t flow through the airbrush. I never decant so maybe someone else can chime in.
Thanks nathan it could have, it sort of clumped up and wouldnt flow.
can any one tell me what the difference between AS and TS is on the tamiya cans?
I have decanted many times without issue. It may have just gotten to thick for the solvent evaporating. How long did you leave it open to de-gas? It should not take too long. Put it in a jar, or whatever, with a loose lid to cut down evaporation but allow gas to escape.
How are you decanting the paint? Through a straw or just spaying it into the jar?
Both are synthetic lacquers for plastic models with the AS being geared toward aircraft.
The “AS” series is a different range of colors specifically for aircraft. I have never seen the “AS” series in stock in a LHS, the only ones I got were from an on-line source. It really doesn’t matter, you can get just about any color you need in the “TS” line.
Thanks for that.
Thanks marc, yer i let it de gas for about an hour. I decanted through a straw, just like the article in fine scale said to do. Maybe its just trial and error
