I am in the middle of putting decals on my current project. It has three coats of Future brushed on, very smooth and glossy, and some decals applied. Is it possible to remove a decal from a surface that has Future on it? The Future has cured for about a week, and the decal has been there for a couple of days.
Or am I just plain SOL? Thanks.
If you have not sealed the decal with Future on top of it yet then there is a possibility of removing it. You need to rehydrate the decal with some water and maybe some weak Setting solution like Micro-Set. Lets this puddle on the decal for 10 or 15 minutes first. Use a #1 or #2 flat paint brush and start sliding it into the edge of the decal - bristles first to lift the edge. Keep it wet and keep working gently - it takes a while but can be done. I ran into an almost identical problem with my RS.14 and successfully removed the decal - see picture below.
This is being lifted after a couple days in place. The decal was salvaged and placed in the correct position.
