I’m going to be decaling over the fine Revell 1/48th Junkers which has great corrugation detail in the moulding. I have to apply 6 Iron Crosses to this aircraft which are approx 1-1/2 inches …over the moulded corrugations mentioned. I have a nice set of Superscale decals for this. Will Microsol work in this case?
It’s always good to make a little test before doing it the big time - on the model, I mean. Tamiya paint bottle with its raised letters on the lid is a great test surface. If you can get the decals to conform over the letters on Tamiya paint bottle, then you need to fear no corrugations. When I started using decal solutions I didn’t believe it can be done - but it can!
The photos of of your model in the aircraft forum showing the bottom wing, the red cross and large WL decals look pebbly and silvered to me from that photo. This may or may not be the case. I realize that looking at photos on the internet may be different than seeing the model in person. If this is the case for real then the Solvaset is not going to work for me on this model and I will have to stencil spray the Iron Crosses. I will try one on the bottom first to see how it looks in person. Then make that decision.
I have been using Solvaset since the early 80s and there hasn’t been one single decal it didn’t work on. The product is very strong and will melt the decal film to conform over irregular shapes. Once it’s on do not touch the decal or you will ruin it.
Just make sure that you gloss up the surface to get a “painted look” from the decal.
I honestly can’t tell how, the red cross sits in the corragations, from that photo. Your photo in the aircraft forum was much closer up, blown up. I’m guessing it looks alright close up.
Thanks for posting that in any case.
I will cut the letters from the decal sheet so I’m really only worried about the larger area crosses, which I will also trim close before trying to apply.
The corragations on the side of the fuselage are deeper than those on the end of wings as well.
