I am looking for some creative edge products to upgrade my 1/32 F-4C to an f-4g. I can’t seem to find who carries these upgrades in the internet. Any help is appreciated.
On the same note, I’m also looking for drop tanks for my 1/32 Tamiya f-15. Are these available as well? I recently scrapped my revell 1/32 Tornado with the hindenburgh tanks. I’m thinking of using these instead. I’m not sure if the dimensions are the same. Only way to find out is build the kit and try the tanks.
Be prepared to shell out some big bucks if you want to convert the F-4C/D to a F-4G. You are better off starting with the F-4E and converting it to a F-4G. There will be less conversion and fewer parts to change. If you start with the F-4C/D you would have to change the nose section, cockpits, wings, AB exhaust and Horz stab. With the F-4E you would only have to use their cockpit , APR-38 fairing, slat conversion, and install the football.
Meteor Productions does have the 600 gal drop tanks for the F-15. The tanks for the Tornado are the wrong dimensions and would not work.
