…why do the Testors MM enamel whites spray so crappy? Ive even switched over to the gloss! it like spits all over.
Would turning up the air pressure help?
I usually spray everything at about 18-20psi.
It almost sounds like a thinning problem. I’ve never really had a problem airbrushing any of MMs lighter colors including white but I do add a little more thinner than I add with the darker colors. When you add extra thinner you mignt consider dropping your air pressure a little. You’ll probably have to do some experimenting to find what works best for you.
