Compressor question.
Hi I have a spray booth, shop compressor, tank, regulator and water separator setup, but the winters are wet and cold too often to spray out there. I see a Master TC-60 all in one tiny compressor on ebay, wonder if any one has experience with that model in particular. Most of my spraying is low demand, air volume flow, mostly around 10-15psi, if that TC-60 would be at all useable for me, I could do some spraying in the house. Easy access to a sliding door, could easily make a light and small booth with hose and duct to outside for safety. I’d appreciate any input from TC-60 users, good or negative. Best to all of you. Patrick
G’day Patrick.
I don’t know that compressor but did you see this amazon ad?
www.amazon.com/…/B009Z2YZBY
Depending where you are you might get a couple of toys with it for less money.
Iv’e used this type for years without any problems.
www.ebay.com.au/…/190408983945
Mick
G’day right back to you, Mick. Thanks for the reply, yes I had seen the Amazon ad. Yours may well be the one to try, I see the one on TCP Global’s ebay ad, and one that appears just the same as from a discount chain store here in Oregon, I think about 90 bucks.
If I don’t hear back from someone that actually has experience with the TC-60, I will likely go with what you have. I enjoyed your website, very nice work and I agree, Don Wheeler is indeed quite a nice bloke with excellent information. He’s become a good friend over the past couple of years, we chat often.
Thanks again, mate.
.Patrick
Thanks for the kind words Patrick, Don was the inspiration with my site, a far cry from his but hopefully will help someone out one day, I have to add a HP.M2 and H&S Silverline to it yet. I love playing with HTML and styles etc…just not good at it :slight_smile:
I just had a quick look at the specs on the Master and I see it has a 0.3 litre air tank where mine has a 3 litre tank, I really think a tank is the go with a compressor but 0.3 seems a bit small. Anyway I’m sure a TC-60 user will come along any time now and tell you all about it.
Cheers Patrick.
