i’ve got the paasche D500S compressor. this thing is far from quiet. it’s fairly loud and creates a good amount of vibration. it hasn’t really mattered up to this point since i’ve been running it in the basement but now that i’m living in a second floor apartment, it’s got me thinking. if i put it on the table it starts walking around on me. i put it on a flat rug on the floor so it doesn’t go anywhere but i’m sure it’s making stuff fall off my downstairs neighbores’ shelves. i can feel the vibration in my chair through the floor. anyone hear of any way to fight the noise and vibration? some sort of special mount? set it on a cinder block on top of a rug or something maybe?
fabricate a frame and suspend it in the middle with a spring at each corner,it’s good enough for studio mics and also ATA approved flight cases,should also stop some of the noise transfer,or you could alsways save up for one of the Badger silent compressors,i finally got mine and have niether problem
I had a large fish tank pump that vibrated like crazy years ago. I tried everything short of shutting it down. Here’s what finally worked the best (hope I can explain it ok):
- Two pieces of particle board (denser than plywood = less transmitted vibration).
- Sandwiched them together with some Chevy swaybar link bushings (rubber bushings).
- Loosly mounted the pump on the top board with rubber bushings.
- Made a vented box (particle board), weighted the bottom down, placed pump & platform in box.
- Placed box on thick carpet padding on carpeted floor.
Everyone seemed happy, even my neighbors down stairs. [;)]
The trick seemed to be getting the box anchored down. Even though I had used two layers of bushings to absorb the vibration, it was still transmitted to the box. Yes, I first tried it without a box straight on the floor. Once I stepped my toes on the bottom board the vibration subsided. So I knew I had to anchor it down somehow. Just like the large compressors in the garages.
Good luck!
Just had a thought!
You could always hang it from the ceiling using a long bungee cord! That should absorb the vibration and not piss-off your upstairs neighbors if you have any. [:-^]
If you have someplace to mount it, it is very simple to eliminate vibration. Buy four extra long Lag Bolts, drill holes through the feet of the compressor and mounting surface. Get eight large rubber bushings, eight large flat washers, four heavy duty springs. Run the bolts up through the mounting surface, add one bushing, flat washer, spring, flat washer, & bushing per bolt. You may have to compress the spring to mount the compressor to them. Then secure with nuts, making sure you have tightned each the same amount.
For some reason it also cuts down on the compressor noise as well as vibration.
I mounted my cmpressor to a small rectangle of plywood , i screwed it to the plywood thru the holes it the compressors 4 legs . Then i got some thick foam and sandwhiched the foam between the 1st piece of plywood and a second piece and held the two pieces of plywood together ( with the foam between them )with four scews , then glued another piece of foam to the bottom of the second (bottom ) piece of plywood. This keeps it from dancing on a hard surface and eliminates a lot of the vibration .
