Hi all,
I bought this kit because it was $15 and I didn’t have anything Japanese. It’s the old kit from 1973, and while it was probably fantastic for its time, it lags a bit behind now.
Still, I thought it would be fun to build, especially since I wanted to practice a new painting technique.
I didn’t bother too much with the cockpit, as I planned on doing the canopy closed, and all that framework will hide much of it anyway.
Assembly was pretty quick. There were decent gaps at the wing roots, but I just used tape to force the wings into position, and it seems to have held up well. Not sure if I have too much dihedral, but it looks about right.
I masked the canopy while watching Eternal Zero, which I learned about in reading Eric’s post on his fantastic project made with this kit (which I won’t come close to, skills-wise).
Now for the painting. I have never thought uniformly shaded panel lines are the way I wanted to continue building models. I like the technique, and I think it can look really good, but I wanted to try black basing with much more randomness, a technique I read about at doogsmodels.com.
After shooting black paint over the whole model, I went back with Tamiya IJN Gray-Green and shot a randomized pattern to give it a really hideous mottled look. It’s great for practicing airbrush control for those Luftwaffe schemes, by the way.
Once I got to this point, I thinned the paint pretty heavily (45 drops of Tamiya lacquer thinner to 12 of paint) and sprayed blending coats over the model until the pattern looked more like an airplane.
This is where I am now:
(Those aren’t the gear doors I’m using. I have them in place as a mask, and painted the other doors accordingly).
I think I went too heavy on the blend coat, and I left it more contrasty on top. We will see which, if either, I actually like when decals are applied and additional weathering, panel line wash and clear coats tone down the effect.
I will either be building this one as one of the Pearl Harbor attack planes off the Akagi or as Saburo Sakai’s mount.
-BD-
