Here is the next project on my list. It seems to be a very complex kit. Something I really enjoy doing. I have also purchased some AM PE and Masks. Please view my WIP as I forge ahead. Thank you for your support and read and replies. Any comments are more than anticipated!
Toshi, that 'Cobra looks to be a far superior kit to the Revell 32-scale kit that I am currently working on. I started mine last September along with three 48-scale Airacobras, but I expect you will finish your’s before I complete any of mine.
One thing I will warn you about regarding the Airacobra is that all of the kits I have ever seen of this are notorious tail sitters. They require a lot of nose weighting to keep them on the tricycle gear. Which then leads to the problem. With all the armament detail up front, where do you out weight sufficient to keeping it from sitting on its tail? The Revell kit not feature any armament detail in the nose so this was not a problem, but this Kittyhawk kit appears to feature all of that detail, which just begs to be displayed.
I sure will and thank you so much in following my builds. I definately more than anything else is to share my builds with you and FSM forum members. Thank you for the read and reply!
Yes sir, your observation is accurate. It will definately be a tail sitter due to the fact that the detailed engine and cockpit will be in the way of some type of weight.
My plan is to utilize a clear piece of stretched spruce and attach it to the very end of the Airacobra. It’s hardly noticeable as I’ve done this already with my Trumpeter 1:32 Me 626. Thank you for the heads up as well as the read and reply!
Toshi .I have the 1 32 revell cobra. And I intend to use one of the trumpeter p 38 engines for that kit …you see I keep those engines like bf-109 …p 38. …mustang. .corsair …hellcat …wildcat …bearcat. …Warhawk …kettyhawk …262 engines. I use them as masters for casting in resin …just to add more detail to those revell and monogram and others to name few .
