Completed 3/26/17 Trumpeter 1/32 P-38-5-LO Lightning
With the Patriots (To Brady’s 5th SB Ring a record) I could only persevered to continue on my P-38 Lightning. Poor Matt Ryan and the Falcons. Oh well. I can only continue to perservere on the twin boom connection of which is the most troublesome area in all p-38 Lighning area’s as far as fit and finish is concerned.
Once I can clear this hump, it’s smooth sailing from here, I hope!!! So far the tape is off and everything has been smooth down and puttied.
Toshi
Ready for for the primer stage!
Ready for the primer stage.
Toshi
Coming along nicely. Looks like a big one
Looking great!
Posted by tempestjohnny on Monday, February 06, 2017 7:06 AM
Thank you tempestjohny,it’s going ahead of plan. Now it’s to mask everything and see where this progresses. Primer and the main coat is the game plan!
Toshi
Hi iampiper13! Thank you, now comes the mask’s and the main coat,then we’ll see where I’m at.
Toshi
Wow, Toshi! You made those booms looks easy. That looks fabulous! :smiley:
Thank you M. Brindos. It took a couple of dry test fits but all in all, I’m pleased with the direction this is going. Thanks for the visit!
Toshi
This evenings additions.
Great work, Toshi. It’s really coming along nicely.
Toshi
Looks good but will look even better if you scrape off the seams along the tops of the MGs. Touch it up after a few passes with a #11 blade.
Thank you sir! I try to do my best!
Toshi
Thank you PlasticJunkie. I missed that, thank you so much for pointing that out to me. Bad cognitive day! I’ll fix that ASAP, that definately doesn’t look good.
Toshi
No biggie Toshi. Sometimes we miss things staring us in the face lol. Also, throw a black wash on the ammo feed belts. It will pop the detail and give a shadow line between each .50 casing.
Got the seams fixed but broke something else. LOL! I’ll fix it, I think I need some away for a couple of days to clear my mind. Thanks again for the tip PlasticJunkie.
Looking Good Toshi. Is this a tailsitter or did they include a weight or “prop”?
