colourrr matching
hello all. I’m just trying to match a colour from the Mr. Color. range. I,ve tried everywere but can,t find one.
The colour is No. 339
the f.s No. is 16081.
I’m tring to match it to The Humbrol or Tamyia range of paints.
If you can help me i woulddd be most thankful.
cheers.
That’s gloss dark gunship gray. The one at the beginning indicates gloss (2 indicates semi gloss, 3 indicates flat). Look up FS-36081 on this chart:
http://www.ipmsstockholm.org/colorcharts/stuff_eng_colorcharts_fs.htm
and it will give you the cross references. You’ll need to add a clear gloss coat after painting (and before decaling!) though.
You’ll also find those cross references at http://www.airmodel.sk ; follow the “colours” chapter.
