Cockpit interior on a Testors/Italieri 1:72 AC-130A
I’m working on an old Testors/Italieri 1:72 AC-130A. Converting it to a slickside to replicate the 3 bladed “A” models that were at Evreux in France in the early 1960’s. Got the kit and went down the rabbit hole :slight_smile: Resin outboard wing tanks, resin wheels, a couple of photo etched kits, braced the wings with some 2mm brass rod, reconstructing the front landing gear to hold the extra weight, and planning to light the interior. I’m looking for anyone with tips on detailing the interior. Need to locate the navigator’s seat precisely because the printed directions are vague. Appreciate anf help. Thanks!!
Hello and welcome to FSM,it may be that your post wasn’t answered because you posted your question in the “Introductions” section,not everyone looks here all the time,or they may not be aircraft guys.
Very interested in watching your build so please post up. I have the 1/72 Italeri C-130J that I’m doing as a Harvest Hawk.
OK. Not sure if I’m doing this correctly so hopefully this will get to everyone. First off, I went down the rabbit hole. Since I have a special spot in my heart for the “A” bird, I needed the 3 bladed props and this was the only kit I could find. Also wanted the outboard resin tanks and landing gear. 1st thing I learned was that there was going to be a over 2 ounces of weight in the nose and that front gear looked like it would blow away in the wind … so I constructed my own using 1mm, 2mm brass rod. Buried the 2mm in a 2.5mm brass tube and added the "elbows. Then I looked at the wings and decided they needed reinforcing. Accomplished with the 2mm brass rod and plastic tube. You can see the build in the pictures.
OzMods has a 130A conversion set. I used it and was happy.
Are you in the US?
Yes. I’m living in South Florida.
Great idea to add the spars to support the wings and replace the nose gear strut with metal parts.
I take it that you’re not going with a “flat face” early C-130A?
Nope. The ones we had at Evreux (1961 to 1963) came from a rotational squadron out of Sewart AFB out of Smyrna, TN. That’s what I’m going for.
