Clear Coat Questions
As I progress my skills and tools into my new hobby of model building I came up to what seems to me a pretty important part of modeling. Clear Coat! I am nearing completion of my Trumpeter Queen Elizabeth 1943 and I didnt use primer or anyting. While waiting on a couple of paints to finish her up I decided to work a little on my next project, the Tamiya KGV in 1/350 scale.
This time I started a little different. I sanded down everything that needed sanded on the hull, and drilled out all of the portholes. I bought some Tamiya spray primer and am going to primer the hull before painting in hopes of a better end result in the look and lay of the paint. I will actually be priming every part before building and painting this kit.
While on the subject of prepaint and assembly, I started thinking to myself about adding a clear coat once the model is done to give it a good finish. I have in my tamiya paint arsenal their xf-86 flat clear. But it is in a regular paint bottle and I feel like brush painting on a clear coat will end in a result that I dont want, which would be uneven and having the possibility of brush strokes visible, and cloudiness.
I feel a spray can of clear would be much easier to get a even coat of clear on it and achieve the look I am after.
So what spray on clear coats work best over acrylic paint? And what methods have you found work best?
For a battleship you should use flat, which rules out Future floor finish.
I use testors Dullcote in a can. I do need to broaden my skills to include a/b flats and it sounds as though there are plenty of good ones.
Hand painting those monsters would be more than I would ever want to take on.
You can use Future for a flat coat by adding Tamiya X21 Flat Base to it. A ratio of roughly 2 parts Flat Base to 8 parts Future is a good starting point. Mix them thoroughly. I suggest that you test on a pant mule before you go straight to your current project.
But there are plenty of dull coats out there to try as well. My personal favorite currently is Humbrol.
If you don’t want to get into airbrushing then I second the suggestion for Testors Dullcoat in a can. Put it on on a fairly dry day though with not a lot of humidity in the air is all.
[dto:]
