Hi, tonight the clerk at the hobby shop told me that after my model is assembled and glued, I should put it in warm water with soap to remove any grease that will prevent the paint to stick on the model.
I was thinking it might be easier to before assembling, putting the sprue in the water would be easier. What do you think?
I wash everything in detergent and water while it’s still on the sprue, using a toothbrush to scrub the pieces. As you say, it’s easier when everything is still attached. This way, I can make sure I reach all the nooks and crannies.
Before painting, I wipe things down with either rubbing alcohol or even a commercial window cleaner like Windex.
Maybe it’s overkill, but I don’t usually have a problem with paint lifting. I use enamels.
Ditto on what checkmateking02 said. I wash them in a large plastic bowl so that if any parts come loose they don’t go down the drain. That’s not a sight you want to see, watching a grown man cry. [:'(]
I am one of the group that washes the parts before I build, using a fish tank net to dip parts into a bowl of water-soap mixture, then to rinse
I only wipe off the finished model with swabs and Q-tips dipped in rubbing alcohol after assembly
even if you do choose to wash in water after assembly,don’t immerse the model in water,water gets trapped inside sometimes,you either end up waiting forever for the model to dry before you paint,or you get seepage during the masking or painting stages
wash the model with a brush, or one of those sponges on a stick,near running water, but not under the stream or in a bowl (I am sure your LHS buds didn’t mean dip it in the water)
