Cleaning enamel
Hello,
I have a Badger 200-3 and want to use enamel paints (Model Master) . Can I use regular paint thinner from say home depot to run through and clean the airbrush.
Thanks George
I have used regular paint thinners, but have also found that a generic laquer thinner does a much better job.
be careful about things labeled “paint thinner” from Home Depot or Lowes or such… I would stick to Lacquer thinner or Mineral Spirits to clean it… otherwise you will be fine with one of the two listed… you can also use mineral spirits as a enamel thinner…
