churchill tank question
Hi all, im reading a book about the dieppe raid, and looking through the pics of the churchill tanks, and I keep on seeing the epic of the Churchill tank, with what looks to be like an antenna raised on te engine deck, is this an antenna or is it something else, would it be on all Mk III churchill tanks.
http://forum.axishistory.com/download/file.php?id=20462&sid=48fc23f089ee50e6ece1a4b93c5d753f
heres a link to a pic I found
If you mean the 2 bent pipes as here by Inside the Armour (other vendors like Millicast & Resicast are available [:-*]) they are the exhaust pipe extensions, bolted directly to the the exhaust manifold, & part of the deep wading kit.
That makes sense, now was that on every Churchill at dieppe? Or just on a few
I would imagine they would be on all. Would make sense to only fit them to some. Heres some more
As for which mark of Churchill, they were a mix of Mk I, II and III.And it says they were all adapted to wade in upto 6 feet of water.
http://northirishhorse.net/articles/Dieppe/16.html
And if your after a kit, which I am guessing you are, Churchill are bringing one out(or may have even released it).
www.perthmilitarymodelling.com/…/afvclub.html
I do not think that Churchill kit has been released yet.
I did find one site which said 25th July, but as we know, that doesn’t always mean anything.
Yeah, I was thinking of just getting a Mk. III and going from there
www.1999.co.jp/…/10220194
wouldnt this kit be the same? I was looking at the plans for it and it looks as if it has the deep wading kit on it?
I can’t see the wading kit in the sprue layout. And there would also be the issue of markings. And I am not sure about the gun. The Mk III had a 6 pounder.
is the 6 pounder equivalant to a 75mm gun, there is a mrkin in there for 1942 I believe
is this a better kit for a dieppe churchill
www.1999.co.jp/…/10074671
I believe a 6 pounder is about 57mm, but I am far from an expert on these types of weapons. I do think that second kit would be a better option. Though as hide from the snorkels, I am not sure what other visible changes were made.
Bish is correct, the 6 Pdr was a 57mm gun. It had a higher velocity and better AP capabilities than the US 75mm gun that was later mounted in Churchills, Cromwells, etc. but the 75mm had a superior HE round.
I see, I heard the joke about the dieppe raid was that the Germans thoughts the churchills were used cause the British wanted to get rid of them
That’s funny. I hope it’s true.
