Chrome Chrome Every Where
What is the best way to get the chrome off parts. I think some of the makers go a tad overboard with it. I think about the only thing with the one I’m doing now that I would still want chromed is the valve covers. Everything else just has to be stripped. Thanks.
hey chris, easy-off oven cleaner in a plastis tub for one day eats that stuff off like crazy.just set your parts in the tub and spray the easy-off all over them just enough to cover, and then wait. easy as pie.[;)][;)]
great, thanks dave. I am going to assume it does nothing to the plastic though.
no , wont hurt it a bit, just be sure to wash in soapy water when stripped and dry well.
thanks, now I just have to ask the mrs. where she has the oven cleaner sine I have used it oh so many times.
I feel your pain Chris…I to think they go way overboard with it. As already mentioned Ez-Off will work though I have never tried it…I heard CSC(castrol super clean) will also work again never used it…I use Chameleon(which is a hobby paint stripper)…pricey but not nearly as harmful as some of the other things I have heard of being used.
ok lizard, after seeing your post last knight, i drop several sprues of chrome in Castrol Super Clear…
waited about 6 hours, pulled the sprues out, and guess what???..all the chrome was gone… CSC works GREAT for removing chrome, and pretty cheaply i might add… around 6 bucks for a gallon at Wally World…
I’ll have to try one of these. Thanks for the info, good thread!
your welcome
Here’s a quite easy way:
I found that just dipping them in 409 of any kind works VERY fast. I’d say within an hour or two. I took the chrome off of a Revel engine model, and it took it all off (and left it quite clean too chuckle) There’s just some chemical in it that takes the chrome off!
I’m not sure if other chemical cleaners like Simple Green etc. work too…you never know how similar they are. Its definately easy to pick any of this stuff up at the grocery store
Good Luck!
-jonathan
Wow so many ways to try. I don’t know what the companies think, I mean on this one the fan belt is chromed, don’t think I have ever seen one like that before.
409 is some amazing stuff. Don’t know if you ever took any window tint off, but the glue that is left is next to impossible to remove. Spray it with 409 and right off it comes. We tried everything else in the detail shop I worked at and nothing else worked without impossible effort. Of coarse the tint shop we called and asked said soap and water would work. To bad we did’nt give up and take the cars to them.
I heard that brake fluid also works, however, i vever tried it…
good luck!!!
Seems like brake fluid would be harder to get off the parts than everything else though.
thats possible, but you can get some old sprue and try it out!!!like i did with the CSC…
Thats true, I have a couple of kits a buddy gave that have something all over the parts. One is a mustang I thought about doing a dio with it all rusted out on blocks and call it dreams forgotten. Would’nt be any chrome on it and if the parts get messed up , it would only add to the look I’ll be looking for.
Souds kool
Use Simple Green to remove chrome, soak parts for a couple of days or so, and chrome will desove, plus it’s not nearly as caustic as oven cleaner.
Lee
Westley’s Bleche-Wite will strip chrome off plastic within an hour or two without harming the part. It’s a whitewall tire cleaner and can usually be found in any automotive store or auto section of your local dept. store.
I used to use straight bleach, which works good too, but the misses hated the smell.
Wow, did’nt figure there would be that many ways of doing it. I might try the bleach since I have a big jug of that handy, just leave it outside so I don’t hear about it.
ive used easy but differnetly then you all, i use a large zip lock baggy and put the parts in then spayed easy off and zipped it up for about 30 mins then yook them out and used a toothbrush and it all just fell off nicely.but remember doing it this way you need to wear gloves.
