Cargo ship question
On cargo ships with deck cranes, the term kingpost seems to be used instead of masts. Question is, do you still call the support guys stays? And if so I suppose forestay and backstay would be appropriate, but what do you call the stays on the side? Are they still shrouds, or are they side-stays?
My understanding is that if it is on the centerline it is still a mast, but if paired on either side, it’s a kingpost. Kingposts usually brace each other through a cross brace between them, either solid or wire, so don’t need bracing with shroulds or stays. But if there is such, wouldn’t fore and aft bracing be a stay and to the sides be shrouds?
Kingpost ( one word, king post seems to be from the days of sail and means something else): A pair of masts used to support booms. Also called Pairmasts or Samson Posts.
The ship I am working on has ony single posts for and aft, but pictures still refer to kingposts. At first I thought there were ratlines on the side stays, but eventually with enough pictures I realized that the shipping line that ran them used to tie ladders to the stays, both fore and aft, on the port side. I guess that was a handy place to stow them! The ladders go about two thirds of the way up to the masthead- or is it a kingpost head?
On the ship I was on (a Navy APA) there were kingposts port and starboard at the forward edge of #1 hatch, a mast on the centerline between #1 and #2 hatches, kingposts port and starboard at the forward edge of #4 hatch, and a mast on the centerline between #4 and #5 hatches. There were no guys, stays, shrouds or whatever you wish to call them at any of the kingposts or the forward mast. Because the after mast had a 30 ton boom on its aft side it did have stays on the #4 hatch. These, as I recall, were spaced symmetrically around the mast to support it no matter which way the boom swung through an arc of 180 degrees. They were not spaced as those on a sailing ship would be so you really can’t call them shrouds or stays.
I’ll toss in my two bits.
Shroud means cloth, or to clothe.
Shrouds on a ship would seem to refer to the effect of a mass or collection of ropes clothing an otherwise naked spar.
I’d say if it’s a single rope or wire, such as a stack stay, it’s a stay. If it’s one of a collection of same, and reasonably coplanar, then those could be called shrouds.
