I know the answer is in forums somewhere but I can’t find it. What will get the gunk from the masking tape off of the canopy after painting without messing up the paint job?
Thanks
Zip
Thanks
Zip
zipmeister:
You can use one of the following.
A. Coffee filter (lint free or more so than paper towel) and a small amount of rubbing alcohol
B. Alcohol Swab that come in foil packet from the Doctor.
C. Q-Tip with a small amount of lighter fluid. Wipe with clear water after to remove any smell.
Cheers;
Gregory
A piece of clean masking tape pressed on the residue will usually pull the stuff off when it is peeld off.
