Found this compressor on ebay, but the seller doesn’t know the manufacturer or model. Claims to be a ‘professional model’ though.
http://cgi.ebay.com/ws/ebayISAPI.dll?ViewItem&item=8122252112
Specs are:
twin storage tanks with regulator, filter/drier, water separator, auto shutoff, silent
115v 198watt 60hz (less than 2 amps) Tanks are roughly 3X3X16 each, they are connected together and have a bleed off vavle. The CutIn/CutOut pressure is set at 25/60psi with a max pressure of 175psi. User can adjust CutIn/CutOut pressure up and down to a max of 175psi. I believe it is about 1cfm. It is auto off, at the desired max psi, which at the moment is 60psi
Thanks! [:)]
