Hi guys. I got some cheese cloth and I am going to try and make a camo net. My qustion is, do I lay it in a container of 50/50 watered down white glue, and leave it in? or do I take it out? If I leave it in, for how long?
Also what should I use to add the thicker line things? I was thinking cut tissue or masking tape. When would I add these In the net, before white glue, or after?
And last of all, How do I get my blaket to keep its shape while it dries?
You soak the netting in the 50/50 water/white glue mixture, then ring it out to remove the excess, then place it in the form that you want it (i.e. if it’s to be draped on top of a turret) go ahead and draped it on the turret. Don’t worry about the excss dripping on your model, it is very easy to remove.
Not sure what you mean be thicker line things but if you mean tie downs I use thin twine that you can find in any hardware store.
The tarp is made exactly the same way as the netting, just be careful to not rip the tissue when you are forming it. If it is blanket over top of a figure, just draped it in place while it is still wet, it will dry into form.
sometimees just painting the tarp and netting in the colors u want can harden them, although this then means that if u try to drape them over ur model, they’ll leave that color on it. then again, that may help in figurin out where u had planned to place stuff on it later…
For years I have used gauze that I stretched to spread out some. Soak like you discussed…then sprinkle dried parsley over the wet surface and drape over your project. Cover your project in seran wrap if you don’t want to mess with glue cleanup.
