Calling shermanfreak, about a... Sherman
Hey Shermanfreak and hello to all! [8D]
Anyone else please feel free to answer[:)]
I’d like to hear your opinion about Tamiya’s M4 early production (bolted front glacis), kit nomber TAM35190. I wonder about tamiya shermans (in general) after reading the article at FSM. I understand that Dragon shermans are superior in detail.
What do you think about the model? is it worth the price? I can get it in a store for abit less then on the internet. thank guys!
The Tamiya early production M4 is a nice kit, it has a nice radio and breach in the turret (what Dragon kits lack) and some nice figures
What you would need to add are lower hull Sponsons so there’s no gaps
In the kit you get the bolted front and the cast front nose. And the Tamiya tracks are nice one piece lengths
the Tamiya M4 is good for a Normandy or Italy setting
Tamiya Shermans are good builds.
They have probalby the best set of pioneer tools available for any currently made Sherman kit.
The solid style road wheels and idlers are weaker than those supplied by Dragon (no greese plugs on the outside surface). But both Tamiya and Dragons solid style road wheels are behind Academy’s in quality (Academy has detail on both sides of the roadwheel).
The main problem with both the Tamiya Shermans and the Dragon Shermans is the VVSS suspension. Both are accurate for a Late Version VVSS. What was much more common on the WWII Shermans is the Mid Version VVSS. These can be substituted for Academy or AFV Club parts, both of which represent Mid Version VVSS systems.
I can only echo that you will need to fill in the sponsons with some plastic stock on the Tamiya kits.
Dragon copied a lot of their parts from Italeri and as a result, copied the errors in the exhaust system on the M4A3’s. And their pioneer tools aren’t as crisp as Tamiyas.
It really comes down to what Sherman do you want to build. The versions offered by Tamiya and Dragon do not cross one-another. Tamiya offers a very late 75mm M4A3 (Late VVSS is perfect for this kit), an early 75mm M4, and the 105mm M4A3 (Again, Late VVSS is OK for this kit). The Dragon kits don’t cover these version. Their 105 was with the E8 suspension, they offered several 76mm versions, and the early Sherman is an M4A1 not an M4. Dragon also added an M4A4 (applause!), but got the lower hull length wrong (it’s too long and need to be cut down). Dragon kits also come with link to link tracks. A positive for me, but a negative to others.
Stay away from the early M4A3E8 offered by Tamiya. It’s not up to par anymore.
Be aware of the older Dragon M4A3E8 releases. They are buildable, but require some cutting on the lower hull to get the suspension in place.
I hope this helps.
Have fun whatever you choose!
To add to what Latch wrote, my son is currently building the Dragon M4A3E8 (ETO WWII version) and keeps asking me why the company made things the way they did… a lot of cutting, some mixed up parts, etc. It’s not a good kit to start with. I’d take one of the currentTamiya Shermans any day over a Dragon kit for buildability… is that a word?? Like everybody else, I wish Tamiya would figure out how to ‘armor’ those sponson undersides! ‘I mean, Like… Duh!’ (to quote one of my students)
Ron
If you are looking for sponsons to fill in the hulls, try this website www.formationsmodels.com No connection with seller.
Well … no need for me to add much here … the rest of the gang pretty much have it covered.
But I will say that I think the Tamiya M4 is the best all around engineered Sherman of the bunch. Yes DML goes a little further with the details, anyone who has struggled through their indy tracks would say too far.
So it boils down to how far do you want to go … if you want an easy, fun, and fairly accurate build, go Tamiya. If you want to get a little more intensive, go DML.
[wow] Latch,
I guess you know your Shermies. Thanks for the info.
Thanks Build22,
I just pass on the info. I have. I too Love the Sherman.
But Shermanfreak is the Master of Sherman Knowledge.[bow]
Psst!! But, Don’t tell anybody,…I have a weak spot for TIGERS!
Thanks gang![:D]
It’s kind’a strange that there are no sponson floors in a tamiya kit…
however I filled it before so I’ll fill it again.
thanks latch66 you sure covered it! and thank you guys for all your replies!
you sure know your shermans![8D]
LOOK OUT GUYS! THERE’S AN 8.8 RIGHT AROUND TH…
