hi mike thinking of getting a airbrush, which would you recomend ?
I’m not sure but I think he would recommend a Badger? He’ll be here shortly. Until he gets here you might want to try to look through the pages of Iwata airbrushes. As a start I would look at the HP-CR brochure.
Oh, gotta go…here he comes now.
how much you want to spend, sean?
some good airbrushes:
badger 100
badger 150
badger 155
badger 175
(not the 360, i assume you would use it for your 1/32 phantom, cups too small but you can use jars)
omni 4000
iwata revolution cr
iwata hp-cs
iwata hp-c
peak c5
most are under 100$$$ from either coastairbrush or dixieart or bearair
I’m not Mike, but I am personally completely happy with my Omnis. I’ve had a 3000 (siphon feed) for a good while and just recently got a 4000 (gravity feed). An Iwata would also be an excellent choice. Based on what I have seen here I would stay away from Azteks though. While a few people have had good results with them, it appears that most don’t.
All of them. [(-D]
That all depends on what you want and how much you want to spend.
I think MusicCity gave some good advice.
Badger!
jeff, do you have a cold my friend?[;)] you might want to get that cough checked out!! i noticed you were barking the same awful cough in another thread close by!![:P][:D]
Badger 100 LG its the same just a big cup. I’ve got its a nice one. And cheap.
Good one, Chris [:p]
[;)] Salty…IWATA!!
You didn’t finish the sentence … Iwanta BADGER!
Not that I’ve joined 1337, but don’t buy an Aztek… I’ve been pretty happy with my Badger 200NH & my next airbrush will most likely be a Badger. Here is a link for some good prices on Badger & Omni/Vegas.
http://www.youcanshopsecure.com/baairbrprli.html
and if you’re into Tamiya airbrushes, here’s a good site…
http://www.buy-model.com/itemlist.php?ItemClassId=V&GroupId=119
Tamiya would be a good choice as well since I understand they are made by Iwata.
jeff, it seems that your cold is getting better friend!
[:o)][:D] i’m happy for you. later.
seeing the workr sean does, i think the best airbrush is an iwata cs, a cr, or an omni 4000
Cheers guys lots of info for me there
