CA and debonder- a no-no!
I did one of those frequent goofs yesterday. Glued the tips of my thumb and index finger together. I happened to have my debonder out on the desktop. “No sweat,” I thought. I managed to get a few drops on the join. Not only did it not work, after a minute or two it began to burn. Ouch! I finally had to call my wife down to the workshop and we took a scalpel and managed to cut the join apart with little loss of skin. But even the small amount of skin lost made the burning worse. That happened in the morning. It still burned in the evening.
Never again! Debonder and flesh are a no-no!
Good to know, Don. Thanks for the info, nice of you to share it.
Patrick
Ouch. [:|]
Thanks for letting us know this “painful” lessons learned.
Happy Holidays
Pat
I did that once…but I was like 9[:P]
I remember a post from a while back, about the burning from the debonder.
Thanks for the tip sir! Sorry it was at your expense.
Toshi
Don, if it happens again, use acetone, or nail polish remover with acetone. Don’t ask me how I know, lol.
My buddy’s daughter used ca on one eye a long time ago when she was about 7ish. She’s in her mid 20s now and can still recall the pain… oh my the pain!!!
Aha ;
Now you know Don . That’s why I keep a gallon of Lacquer thinner around . So I can just dip the affected fingers in there .Sorry you learned about de-bonder that way though . T.B.
Having spent some time building balsa models (R/C), I have gotten CA on my fingers a time or two. I used acetone to clean it off and it did a fine job. I am sure too much acetone on your skin hurts you. Now I rarely use CA.
Put your bonded fingers to cold distilled water and it will deboned in a few min.
Water is the enemy of those types of glues.If you glue plastic w/ these types of giues and submerse it in water.Then it will loosen bond.
Thx Don,
Oh my god, NO! I would not recommend that AT ALL. Lacquer thinner is HIGHLY toxic and will permeate your skin instantly.
People don’t realize that your skin is the largest actual “organ” of your body. When you drop something on it or soak your skin/fingers in something, your skin absorbs it. Lacquer thinner is a known, and highly toxic, carcinogen. DO NOT continue this practice.
Even acetone is no better, but if you get your fingers stuck, you would be better to use a Q-tip and sparingly use the tip to gently dissolve the bond.
We who work around these highly-toxic chemicals for sake of producing the models that we love need to remember that these chemicals can build up and kill is over time. Please take this seriously, guys! [:O]
Try water.
If you go to a doctor w/ your bonded fingers he will 1st use a water treatment to Debond your finger.
