I was reading on of the forum notes about bullet holes. Someone talked about a methode of thinning the area down with a dremel and then using an exacto knife. Does someone know the whole procedure. It sounded very interesting, and I would like to know more if possible
Thanks in advance
It’s in the aircraft forum titled bullet holes. dremel from the inside. good luck…
G.L.
HEY,
all you have to do is take a #11 hobby knife and put the tip where you want the bullet hole. Turn it and push lightly until you get to the depth that you want. But dont go too deep or you will go through the plastic. And finally you paint the inside of the hole silver and i have found that this technique works pretty good. Hope this helps
Randy
once again the experts have come through. Thanks alot
