Making slow progress on this one. When dry fitting the hull parts I noticed that it was difficult to get the compartment floor, side walls and rear wall to square upp the way I wanted so I decided to bite the bullet and do them first.
Rubber band and Loctite SG did the trick - looks OK now.
A bit of filler will fill the gap…
I managed to break the fragile pedals while pushing the parts, will get them back with some brass wire.
The engine wont be visible with the hatches down but looks quite nice.
The steering wheel angle can be build adjustable [:D]
Some close upp of the VHF Radio (The Images are from the site www.radista.info)
Been relocated to KL and the compressor is still stuck in customs - somewhere…
NW, I am killing time with a BTR-80 I managed to get into the cabin luggage.
@ talentless - thank you for taking time and your comment - I am using magnifiers myself but will see if I can get a closeup when the gear arrives [H].
Johan, you’re an artist/ modeler after my own heart with that heavy pre-shading paint That’s very similar to how I paint mine, and I have rarely seen anyone else use that method. I can’t wait to see what you do with this! The build itself was great, too!!
