Here is my issue. I am currently assembling the 1957 Chevy Stepside 1/2 ton 1:25 scale. In the instructions it recommends that the chrome wheels be painted the same color as the body.
I will be using Tamiya X-8 Acrylic paint (Lemon Yellow) on the body and it will be no doubt thinned for airbrushing. Here is the question, should I thin the paint to be used on the chrome wheels or just apply at full strength?
yeesh…yellpw…so translucent…5 million coats to cover with brush…hehe. You could use your airbrush to paint them, just mask areas you dont want oversprayed, or if you have a regulator, turn the pressure down a notch and get a little closer. I always thin when hand painting. Usually 1:1 or 3:2 (especially acrylics, they dry so fast). I would recommend priming though with white to make the color glow, yellow has a tendancy to turn dingy when hand painted over a dark surface.
Thanks for all of your tips. I don’t want to strip all the chrome from the wheel as I need only to paint the face of the mag and leave the rest of the wheel chrome. I have already primed the area with white and will apply the body color this week.
