British Airways Concorde G-BOAG Model
This is my second attempt at model making after bringing a Revell Peterbilt Black Widow truck back from the dead. This time I wanted something a little easier than the truck to gain more practice so I chose Concorde. The model was easy enough to build but I had fun and games with the endless amount of transfers / stickers / labels (not sure what they’re called in America). The lack of a stand made me come up with a weird and wonderful way of displaying the plane as I have no idea what you guys would make for a stand but I am pleased with the end result.
It’s far from perfect and if you look closely you might find one or two damaged transfers but it’s only my second model and I learn something new each time I make a mistake so I can only get better (hopefully).
All comments, suggestions and tips are welcome because if you don’t tell me, I might never know.
Elizabeth
I never took any photos when building this model as it was just a case of glueing the wings and nose on and spraying it white. I then fitted the engines and landing gear before nervously applying the transfers.
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG1.jpg?t=1301207798)
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG2.jpg?t=1301207798)
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG3.jpg?t=1301208013)
When I first opened the box Concorde came in I was disappointed to not find a stand. So I had a rummage around and came up with the base of an old ‘helping hands’ tool and an aerial from a CD player.
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG4.jpg?t=1301208054)
I worked out what angle I wanted the plane to be at then cut out the centre from a chrome parts frame and glued it to the top of the aerial. On the underside of the plane I fitted location pins which fit inside the square chrome piece. I can now position the plane any way I like by moving or extending the aerial.
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG7.jpg?t=1301208138)
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG5.jpg?t=1301208161)
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG6.jpg?t=1301208205)
Just taken off from London Heathrow …
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG8.jpg?t=1301208257)
… to arrive in New York JFK in three hours and 20 minutes.
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG9.jpg?t=1301208320)
Fully extended stand.
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG10.jpg?t=1301208393)
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG11.jpg?t=1301208460)
Now that Concorde is finished I have started building a Revell Dumper Trailer to go with the Peterbilt Black Widow truck that I built.
!(http://i1121.photobucket.com/albums/l515/Elizabeth--Jane/Concorde G-BOAG Model/ConcordeG-BOAG12.jpg?t=1301208516)
Very neatly done! [:D[
I especially like the clever and imaginative stand. [Y][t$t]
Re: the term transfers:
I’ve used either transfers or decals.
BTW…don’t let Manny try to tell you it needs more rust…[whstl]
Very nice model, E. But what jumps out is that the visor is up, as it would be when parked or at high speed, yet she’s in subsonic flight, gear down. I like your inflight display, and I’d suggest you snap off the landing gear, close the doors and she’ll look very slick indeed.
Really well done… model and stand.
I agree with bondo. I would think nose up, wheels up on the bird.
[Y] very nice job on the build enjoyed the pics.
Ron
very nice and clean build! [Y] What scale is it?
I have to tell you that’s a nice, clean, and sharp build up. The display stand is smart and the lines on the Concord are great. Well done Liz.
Elizabeth- very nice work indeed! Your stand is very creative also. [Y]
We use the term ‘transfers’ here in America, but another common term is ‘decals.’ Looks like yours came out well, despite the fun and games you had with them. That’s definitely one aspect where we’ve all shared in the fun and games.
Looking forward to your dumper trailer…
Very nice concorde! [Y][Y] Is it 1/144?
Lots of things to learn but you’re on the right way [:$]
Surely better than my second attempt to build a plane [Y]
Sprue-ce Goose: Decals! That’s a good word for them. I never thought of that one. So, decals it is then.
bondoman: err … oops! Landing gear down, visor up. I guess you wouldn’t believe me if I said that was a deliberate mistake? [whstl]
CallSignOWL: It’s a 1/144 scale Revell model.
Best of luck building your articulated lorry’s trailer !
Very sharp looking model![Y]
Stands can be made pretty easily. I use premade unfinished (I stain them) plaques from a craft store and brass rod/tube or 1/4 inch wood dowel. Just drill a hole, the same size as the rod or dowel, about half way into the wood, and a hole (at whatever angle you choose) into the model. If you use a small gauge rod, you can bend it just before it enters the model. This will allow you to change the attitude of the plane by spinning it around.
In this shot, you can see (just to the right of the C-130s) an F-15 that is mounted the same way, but hung on the wall.
Congratulations on a very nice build Elizabeth! That’s a nice model indeed. Well done!
Gary
sharp looking , ! nice ![:)]
keep up the good work !
Wow. Very nice build Elizabeth. Great job. I think it looks fine the way it is.
Nice looking concord Elizabeth.
Be careful… looks like there is a giant bear in the takeoff traffic from Heathrow [;)]
Howdy!
Another nice one! Just the “painting it white” is a feat not everybody can pull off as good as you did! Keep ‘em comin’ and have a nice day
Paweł
