Brass Brumbar Zimmerit (say that 3 times fast!)
Hey Guys,
Gotta zimmerit set for my Tamiya Brumbar. Its fairly large sheets of stamped brass. I know you use super glue on small photoetch, what about larger pieces where you might want some working time?
Thanks
Chaz
Welcome to the forums. This is a great place to find out some stuff
I have used, based on several recommendations, 5 minute epoxy on large PE stuff. I haven’t used PE zim, but on the fenders of my Stug, the epoxy worked great. (Thanks to Moses). You should probabbly do a test run with scrap brass and plastic sheet to test your applying techniques to get an even layer.
I think Wbill used it on one of his models recently, can’t remember.
Also, the gel type superglue can give you a little more working time, but I have found it will want to grab and stick immediately from time to time without rhyme or reason.
My $.02.
HTH,
Ted
