Braided hoses for motorcycle
Has anyone replaced the standard tubing on a 1/12 motorcycle build with braided hoses?.. If so what size/diameter?.. I bought a tamiya braided hose pack which was 2mm outer diameter with 0.8mm internal diameter but it looks way to thick to be in scale… Thanks in advance
There is an electrical cable that does a good job of simulating braided hose. It is used for microphone shielded leads. Comes in a few sizes. Smallest size even works on 1:24 scale. Small coax might even work for 1:12. Both are a little hard to find, only available from large electronics venders.
Not sure what the right diameter is for your application but check out Top Studio. They do amazing detail sets for cars/bikes.
Here’s a link to some braided lines down to .6mm
http://www.topstudiohobby.com/index.php?route=product/search&filter_name=braided
