This is my last project, a Borgward B IV. It’s Dragon’s 1/35 kit and it’s only slightly larger than a 1/72 tank.
It’s a late A or early B, however you look at it and was built for an Anzio build. These little monsters weren’t successful there due to the muddy terrain, which I tried to reflect in the build. I left the Borg with a shine and added puddles in the bootprints and tracks to get the look of fresh drizzle.
I cut down the wheels and sunk it in a plaster, sculpting it as it set up. I then Airbrushed the base and the bottom hull red brown. After that it was simply some binder with pigment and real dirt added to the tracks, wheels and scattered on the ground. Finished up with Future dumped in the impressions for standing water.
No figures, it’s abandoned.
Ryan, they were explosive carriers. They could be driven to a location, then controlled by radio from there. The boxy thing in the front is the charge that could be dumped and then the rest backed away before detonation. They were used for clearing minefields or assaulting fixed positions.
Thanks for sharing the pictures and the plaster/mud technique Ausf. Now if we could only get you to lend some of that German freehand camo skill you have. Does that come in a pill or syrup ?? [:D][;)]
