BOB FS numbers needed.
Hi al, I need the FS numbers (MM enamel paints) for the colors used by sptifres in thr battle of britain.
So far I’ve got: FS30095 or 30118 for the dark earth
FS34079 or 34096 or 34064 for dark green
FS34583 or 34504 or 34672 for the underside sky.
Now whihc one of these would you guys go for as the best match? Also, what color to use for the interior cockpit color? FS number would be helpful. (Even if it’s just the US color I need to lighten with white.) -Thanks.
Tank
Model Master already makes the following: RAF Drak Green, RAF Dark Earth, RAF Interior Green, RAF Sky Type S. These whereused on the Spit below. The Sky can be seen on the spinner and fuselage band.
Hope that helps.
well that certainly does help! Thanks nut! [:-,]
Why so formal, please… call me wing[;)][:D]
