black pre-shading and chipping
Hey all, been a long while since I’ve logged on. Anyway I’m back and esstactic to do two things: First- I FINALLY took the plunge into the world of airbrushing. Second- Just as I learned that Revell had discontinued a whole messload of models, I happened to come across what apparently was the LAST B-17 available in my area.
Anywhoo, here’s my problem. (And I apologize if this has been asked/answered, no amount of phrasing I tried, got to the exact question I had in mind).
I plan on doing a base black coat with various shading, rather than shading individual panel lines. So with that in mind, how would I go about layering, given the fact that I’ll also be going for the chipping effect and not have the areas I wanna chip, look vastly different (shade wise) from other areas of the plane?
My thinking is- the aluminum that shows through with chipping is the plane’s true color, so no matter what the paint scheme is, or how far into hell and back the aircraft has been, it’s foundation is aluminum. So should I paint the entire plane in aluminum, put the chipping effect over areas I wanna chip (or all over to eliminate guess work) and then proceed to shading (starting with a black coat)? That way no matter how man layers of shade I add, when I chip; what shows through at the bottom is bare aluminum (which can be weathered, dirt/grit wise later).
I seriously think I solved my dillemma, trying to find a coherent way to explain this lol, but I still would love to hear what you guys think! Thanks and cheers!
I would black base the whole plane and just use aluminium in the areas that you want to chip.
Steve
What I did on my last build (Hasegawa P-40E, you can look back a few weeks ago and find it in the aircraft section) was to do the black basing, followed by the base color in various shades to simulate fading and added chipping effects at the end with a fine foam sponge material dabbed in aluminum paint. To me this was much easier than chipping away to an underlying aluminum paint. That’s just how I chose to do it and I was happy with the results.
An old method often used is to do the areas you want to see chips in aluminum, maybe the whole aircraft. You then apply a masking material where you want chips and then shade and finally the camo colors. Peel your masking material and you have natual metal “chips”, or wear spots. Try a few methods and use the one that works for you.
Currahee, MOS 11Bravo. Two things fall out of the sky, bird droppings and airborn. I took the last train to Clarksville too. Kilroy was a weld inspector in a ship yard and he would signify where he had inspected the welds in the ship with “Kilroy was here”. The troops that took the ships over to Europe (and the Asian theaters?) created the cartoon and it spread like wildfire. I think Bill Mauldon’s cartoons in the Stars and Stripes may have helped the spread of the cartoon character and the expression “Killroy was hear”.
Depends on the scale, as far as I am concerned. In smaller scales I just use a toothpick or very fine tip brush during weathering. I just put down very small dots and lines to simulate scratches and pits in paint. In large scale, where you can percieve something about the depth of scratches, using an aluminum base and fancy schemes may pay off. However, for just a few chips and scratches here and there, I have even just used the aluminum paint over the final finish and it looked okay. Drybrushed aluminum looks fine on large scale.
Thanks for all the tips guys! I think I might do the toothpick/wool technique. Pics when I’m done!
